What ratio's do the coil sprung solid front prado's come in . I know 4.3
Also if someone has one on the shed floor can you measure from the radius arm mount to the edge of the diff flange on each side . All I am after is finding out how much the diff head is off set , ie if one side is 400 and the other is 100 the head is offset 300mm , so what you meassure from on radius mount does not really matter so long as its the same on both sides .
Otherwise I will wait untill I see one in a carpark somewhere
Chris
