landcrusier ignition lights
jase99
Newbie
Newbie
Post by jase99 »
Hi guys
new boy to the site
got a problem with my 80 series landcruiser.
ignition lights flicker on while driving
anybody got any idea what it could be.
jase99
kbushnz
Re: landcrusier ignition lights
Post by kbushnz »
Bad earth to instrument cluster.
Loose connection to instrument cluster.
Loose bulb in instrument cluster.
Bad battery terminals
Bad fuse able links
A Something is loose?
Calvin :mrgreen:
wopass
Post by wopass »
or the alternator is on the way out. check battery connections first.
badnuz
Post by badnuz »
yup check your battery terminals, if they are loose then you may be buggering your regulator in the alternator.....
