my hilux surf 1kzte viscous fan hub never locks up , i have replaced the oil in it and it hasnt done eff all, i would like ot adjust it to lock up earlier, how do i do this?
cheers vince
how to adjust viscous fan hub to lock up earlier
vinceparts
Re: how to adjust viscous fan hub to lock up earlier
vinceparts wrote:my hilux surf 1kzte viscous fan hub never locks up , i have replaced the oil in it and it hasnt done eff all, i would like ot adjust it to lock up earlier, how do i do this?
cheers vince
pull the fan off the motor, apply heat from heat gun to spring on front of viscous, see which way the valves turns, you then need to pull the other end of the spring of the ali housing,and tweak the spring to make the valve be "on" more when the spring is put back into its seat, if you over do it then the fan will never turn off. tweak it back then
did it yesterday to a rover viscous
Pedro
vinceparts
so if it moves clockwise i need to make it move more clockwise , and by tweaking the spring you mean, streting bending or will there be adjusting nuts of sum kind to reposition it?
what oil did you use? cheap stuff or Toyota OEM
Toyota viscous fan oil comes in 3 different grades/ viscositys , and quantity must be exact.
you shouldn't need to tweak the hub at all
LR110 ..... LJ50 project
vinceparts
i just poured 3/4 of a bottle of that bnt shit in there, what do i need to do exactly and how do i do it and what parts do i use
there Is a thread on toyotasurf.asn.au that gives all the Toyota part numbers and a full right up
Or just buy a new viscous hub for $120 from BNT. Problem solved.
vinceparts
woah didnt realise it was that cheap for a new hub, i can get good discounts too so new hub it will be
thanks
thanks
