help!!!
samewan
help!!!
Post by samewan »
OK well on a quick mission down to the river I hit a bump and was a loud bang,that was fine, there was no 4wding just gravelroad. Further down the road it started to develop a rather large vibration. driving home it steadily got worse and worse.on futher inspection the cross member is bent but everything else is fine will post pics and check engine mounts and gearbox mounts in the morning.
any idears what it could be?
cheers sam
Lynx
Re: help!!!
Post by Lynx »
Umm what crossmember?
samewan
Re: help!!!
Post by samewan »
the gearbox cross member
samewan
Re: help!!!
Post by samewan »
sorry in a surf ln130
Lynx
Re: help!!!
Post by Lynx »
Id be checking the mounts man, pretty hard to tell from here aye. Theres no puddles of oil or anything under it yeah?
niblik
Re: help!!!
Post by niblik »
steerin arms ok? wheel shimmy? can ya explain the vibration a tad more? wheel shimmy? only when drivin? when sittin still idling?
gotta be asked, how the hell you hit somethin big and hard enough to bend a cross member but not collect a diff etc, or see it prior!!? :mrgreen:
just lay under there and locate the vibration.. you'll get there..
samewan
Re: help!!!
Post by samewan »
I just did a three point turn and collected something as I drove back onto the track it's like siting in a massaging chair it does it whilst the engine is on faster you go the worse it gets @ 100 it's so loud you can't even talk to your passenger
Lynx
Re: help!!!
Post by Lynx »
Driveshaft
samewan
Re: help!!!
Post by samewan »
checked that no dents or anything on it
niblik
Re: help!!!
Post by niblik »
checked the uni's?
happens while engine is on.. you mean idling it happens or only when ya drive?
samewan
Re: help!!!
Post by samewan »
the whole time the engine is on and had a quick look they look ok
SMOKEY
Re: help!!!
Post by SMOKEY »
Check EXHAUST. FITZY.
UBZ
Re: help!!!
Post by UBZ »
^^^ what he said
aslo check your rear gearbox mount , engine mounts and that your transfer case skid plate is not mashed into your transfer case.
samewan
Re: help!!!
Post by samewan »
EXHAUST mounts? and the transfer bash plate is fine i just brought a new crossmember so ill throw that on and see what happens.
samewan
Re: help!!!
Post by samewan »
on futher inspection i found this
a little bent
a little bent
cross member.jpg (26.11 KiB) Viewed 3267 times
between drive shaft and rear diff oil leaking
rear diff.jpg (24.62 KiB) Viewed 3267 times
between front diff and cv joint
front diff.jpg (25.69 KiB) Viewed 3267 times
hmm thats abit of diff oil
diff oil.jpg (43.47 KiB) Viewed 3267 times
samewan
Re: help!!!
Post by samewan »
any one?
samewan
Re: help!!!
Post by samewan »
if no ones has a clue can some one point me in the direction of GOOD mechanic in chch that doesnt charge a fortune?
niblik
Re: help!!!
Post by niblik »
that oil leakin from your diff housing front pinion would be from lack of a goody one of these..
so in order to do one of those, just follow this link.. http://www.autozone.com/autozone/repair ... 52800611d5 :wink:
that wont be the cause of ya shimmy unless ya really crunched ya front pinion, then ya should be able to get under there and wobble it around relatively easily...? tried that?
Re: help!!!
yes Rick at 4wd accessories :D nib's knows where he is now
niblik
Re: help!!!
Post by niblik »
coxsy wrote:yes Rick at 4wd accessories :D nib's knows where he is now
on the sockburn roundabout side of watts road. about 2 or 3 driveways from blenhiem road end... :D
hosehustler
Re: help!!!
Post by hosehustler »
Hi Sam,
i'm with Fitzy's opinion on the exhaust, if it's doing it when the motor is at idle (vehicle not moving) it's most likely to be your exhaust hitting body/chassis somewhere.
I'm home on Wed if you want to drop in I can have a quick look, but Rick@ 4wdacc won't rip you off.....34 Watts rd :wink:
I hate signatures
samewan
Re: help!!!
Post by samewan »
sweet hes just around the road from were I live with the amount of oil ive droped i dont think that it would be a good idear to drive so might not be able to pop out thanks any way tim
just brought a new cross member 20 buxs not to bad and ill talk to rick and see what he thinks thanks for all your help guys
samewan
Re: help!!!
Post by samewan »
ok so my front diff was fffffffffdd any way so im just going to buy a new front diff i see they are about 200 buxs on trade me anyone know were else to look and how hard they are to change?
found out what the large vibration was the gearbox was hitting the bodey of the truck i managed to push it up.
the rear diff i got to have a look at it i want to put a lsd or lokka into it any way so i dont know.
niblik
Re: help!!!
Post by niblik »
why put a lokka or lsd in ya daily driver if ya wantin to keep it in good order and use a dedicated offroader?
sounds like ya must have taken a massive punt in order to fawk the crossmember to do that.. ruff carnt. :mrgreen:
niblik
Re: help!!!
Post by niblik »
samewan wrote:ok so my front diff was fffffffffdd any way so im just going to buy a new front diff i see they are about 200 buxs on trade me anyone know were else to look and how hard they are to change?
the whole diff from hub to hub or just the head? easy to change on both counts..
samewan
Re: help!!!
Post by samewan »
just the diff head as its in a ifs i can just buy that bit ae? and swap it over?
btw i like ya surf im just waiting on my pay out before i make in decisions.
but i would be keen to help ya pull it out and have a go over oneday to get a god look at it.
niblik
Re: help!!!
Post by niblik »
samewan wrote:but i would be keen to help ya pull it out and have a go over oneday to get a good look at it.
talkin about the truck aye? :mrgreen: :lol: if so, already done.. :D
samewan
Re: help!!!
Post by samewan »
far dude ruin my fun aha sweet i quite like it ae and there is sweet f/a out there so im keen . just got to get my d/d up and running now its alittle bit shit walking every were.
samewan
Re: help!!!
Post by samewan »
so just rung up lineside and they want 450 plies tax for a diff maybe 200 wasn't so bad after all
hosehustler
Re: help!!!
What ratio front IFS diff are you after, I have that 2 door surf I showed you which i'll be wrecking very soon which has one in it.
Tim
I hate signatures
Return to “Toyota”
