185 surf lift suggestions
wildplumdx
i've just got a 185 surf and was wondering how to go about lifting it.
which springs are best for the money ? i've had good experience with dobis springs in the past in cars not 4wd's but how do they stack up in 4wd scene ?
don't really want to spend anymore than 1g lifting less if poss
also i have an old ln130 that has red lift spring in there rear not sure what brand, that i could take out if there any good for the 185 ?
opinions ?
cheers guys
opinions ?
cheers guys
Re: 185 surf lift suggestions
130s and 185s have different rear springs...
wildplumdx
bastards.....how about towbars ?
wildplumdx
just rang repco and they can do cobra springs for 375 a pair front and rear.... that seems expensive as hell
check out lovells brand, what i had in my terrano, and only 200 bucks a pair.
is that a pair front and rear or a pair front OR rear?
wildplumdx
375 a pair and i need 2 pairs , i'll check em out dirty thanks
wildplumdx
will this fit a 185 hilux ? http://www.trademe.co.nz/Browse/Listing ... ermanent=0
well mounts could allways be fabricated for it, but may not fit the shape.
- evolution02
wildplumdx wrote:will this fit a 185 hilux ? http://www.trademe.co.nz/Browse/Listing ... ermanent=0
With the 185 you will need an airbag compliant bullbar. Try Ironman they look good and probably the cheapest new
- floatingkiwi
Also try the MCC bars, look good on a 185 but I have no idea of quality.
You can call me for all sorts of 185 info if necessary (done lots of 185 suspension and bar research):
matt 02102410351
matt 02102410351
1999 KZN185W SSRG TJM T-15 Bar, Tigerz11 2speed winch, 2" EFS sus lift, 265-75R16 Engine guardian. Auberins EGT. LED light strips. weathertech cargo liner. Safari Snorkle SS145HF. Prado rad. Front and rear E-locker.
ring these guys they do a set of rear springs for 260 cobra brand
Chamberlain Auto Springs Limited Christchurch
wildplumdx
So got 2 quotes so far 520 for set of cobras or 460 for a set of lovells think I'll grab the lovells!
