Steering Damper or RTC D21
For all Nissan related topics
BogBoy
Post by BogBoy »
Ok so had a search and I see this has been covered alot in the past
I have a small problem that I am running a 2wd center link that has no mounting bracket on it all.
I also cant see some were to mount it on the chassis. :cry:
I was talking to toms offroad customs and he said it might have one factory but might not. I dont want to have to get one welded on as that would mean cert........
nismo26
Re: Steering Damper or RTC D21
Post by nismo26 »
Get a bolt on mount for the centre link.
BogBoy
Post by BogBoy »
nismo26 wrote:Get a bolt on mount for the centre link.
And saying that is as much use as telling me to run around three times then clap my hands :roll:
What sort? Brand? Were to look?
nismo26
Post by nismo26 »
Any that will fit something like this would be easy to make, I think you can get the Ubolts from Blacks, If you give me some measurements I can make one at work.
http://www.4wdsystems.com.au/index.php?id=60
Dirtydog
Post by Dirtydog »
shouldnt cost alot to get one made up, 2 u bolts and some small bits of plate metal, couple of holes drilled. would take a good engineer maybe 5 minutes to make.
as for the chassis mount, you may be able to get something made to bolt onto where the idler arm is bolted to chassis, but on the inside of chassis.
Heres a pic of close to what i mean:
EDIT:
This is what ya want
BogBoy
Post by BogBoy »
Dirtydog wrote:shouldnt cost alot to get one made up, 2 u bolts and some small bits of plate metal, couple of holes drilled. would take a good engineer maybe 5 minutes to make.
ive seen bolt on ones before but cant remember where, probably a U.S site.
Wicked. Can that spot still be used when I change it to a 2nd steering box type?
slide
Post by slide »
Had a bit of a search, moog part#DS1061 /ACDELCO part#45B1081 looks like
And the factory 4x4 steering system (lhd in pic) shown with steering damper. Damper pin bolts to chassis near bolts that hold idler arm (mounts to inner of chassis). Pin can be ordered through Nissan, or you might find a secondhand one somewhere. Its shown clearly in dirtydogs pic above in LHD format, so yea, would fit with steering box idler
BogBoy
Post by BogBoy »
Does any one know were to get one of these?
Dirtydog
Post by Dirtydog »
probably cheaper to make one,
two u bolts and a bit of angle/flat bar bent to shape with a couple of holes drilled.
zukmeista
Post by zukmeista »
Seeing as it hasn't been mentioned, the return to center spring loaded steering dampers are a waste of time. You will be better off to just buy a normal damper.
BogBoy
Post by BogBoy »
Dirtydog wrote:probably cheaper to make one,
I was thinking that but how would it be for wofs?
Dirtydog
Post by Dirtydog »
aslong as your not applying heat or modifying chassis mounts etc you should be allright.
if you make use of the idler arm mounting bolts (even if you have to buy longer ones) and just bend up a peice of flat or even a piece of angle.
Best bet would be to chat to who does you warrants though as theyre the one that makes the decision in the end.
Also im interested in something, can you use standard shocks (as in the ones that dont extend by them selves) for a steering dampener?
BogBoy
Post by BogBoy »
Dirtydog wrote:aslong as your not applying heat or modifying chassis mounts etc you should be allright.
Ahhh sweet
Hmmm Im not sure about the standard shock use? I brought a "damper" to be on the safe side.
The new damper pin I have coming from japan uses the factory holes but only with a idler.... Fingers crossed it wont need a mod when fitting the 2nd steering box.
Dirtydog
Post by Dirtydog »
with the dummy box you use the same bolt holes anyway im preetty sure, might have to look that up though, so wouldnt change much.
BogBoy
Post by BogBoy »
Dirtydog wrote:with the dummy box you use the same bolt holes anyway im preetty sure, might have to look that up though, so wouldnt change much.
Yea think that might be the case with only one needing to be drilled out hence using the larger washers?
poss682
Post by poss682 »
where did you get the damper pin from in japan
Ralfie
Post by Ralfie »
zukmeista wrote:Seeing as it hasn't been mentioned, the return to center spring loaded steering dampers are a waste of time. You will be better off to just buy a normal damper.
Care to justify the reasoning behind that statement?
zukmeista
Post by zukmeista »
What is the point of a spring? All it does is push the steering back to the straight ahead position which would be a nuisance offroad, as if you need more resistance when you're trying to turn the steering wheel :roll:
Smurf
Post by Smurf »
Ever used one?
I have, liked it a lot, will be fitting another.
GotFlex
Post by GotFlex »
I had one of the RTC on my truck was awesome on the road and even better offroad
That bracket you guys are chasing can be bought from opposite lock here in aus, but it's a proper clamp style with 3 cap screws about $20aud
lax2wlg
Post by lax2wlg »
I dont really see the point of a steering damper in terms of prolonging steering component life. I get that it reduces the vibration/shock felt at the wheel, but as I see it, by the time any shock force has reached the damper, it has to have travelled through the tie-rod and one end of the center link first.
But it feels nice.
BogBoy
Post by BogBoy »
poss682 wrote:where did you get the damper pin from in japan
Nissan in japan.... :D
poss682
Post by poss682 »
do you have any part numbers or any info that would help me buy one who did you contact, crockam nissan?
BogBoy
Post by BogBoy »
poss682 wrote:do you have any part numbers or any info that would help me buy one who did you contact, crockam nissan?
Yep Cockam Nissan.
Part number is 4861231G00
10 working day delivery
$42.26 including GST
Return to “Nissan”
