Can anyone tell me what this raspy/rattly noise is. i cant figure out what it is and its very annoying. Its intermittent, sometimes noisier than other times. Started happening mid way thru wheeling at the waipara
Truck is manual
https://www.youtube.com/watch?v=ABRr65R ... e=youtu.be
Cheers.
80 series help
80 series help
Re: 80 series help
Is it auto or manual ?
Sounds like Big end bearings starting to go (my audio is shit )
If you have'nt already replaced them we stock genuine big end bolts and acl full life copper nickle bearings to replace the shit alloy toyota ones that need doing at 100,000km intervals ,
Re: 80 series help
Its manual. You got me worried now. I would have thought if it were the BEBs, it'd have thought it would be more of a knocking/ticking sound?? I haven't seen any noticeable drop in oil pressure either.
Re: 80 series help
Does the noise change if you put your foot on the clutch ??
Re: 80 series help
Trundle wrote:Does the noise change if you put your foot on the clutch ??
Yeh my old manual 80 series mad a similar noise, ended up being a clutch spring. Changed clutch, no more noise. Would rather do BEB to be honest. alot easier
Re: 80 series help
No doesn't change when i put clutch in, its not a rattle. It sometimes is there sometimes its not, still there no matter what revs i'm doing. I can't hear it when i'm inside, only when the window is down. The noise of the engine just drains out the sound when i rev it up. the noise doesnt get worse with higher revs.
heres a jeep with the same noise: https://www.youtube.com/watch?v=Qk32yYm ... ag&index=2
Re: 80 series help
could be release bearing fkd.. the bearings are running dry..would make a sound similar to that.. Had similar on my truck too..
So that means drop box off and have a looksee.. check clutch as well
Re: 80 series help
Alternator bearing
cheers.
cheers.
