Does anyone out there know if toyota has a different length steering shafts to overcome a lack of spline in the yoke.
I am sure this has been discussed before but cant find any posts
hilux steering shaft to short
- muddy_munke
Re: hilux steering shaft to short
Steering shaft? As in from the steering wheel to the steering box?? if this is the case. yes, the 2wd ones are a bit longer. I have put one in my truck as I moved the steering box forward when I put it in.
cheers I knew there was a solution but just couldnt find it on here
- muddy_munke
When you do it, you may need to swap the rubber end over. You know the rubber type flexible coupling. I had to do it on mine. I can't recall why now though.
Daniel
Daniel
- hosehustler
Steering shaft from a ln61 (IFS) is longer than a steering shaft from a ln 60 (beam) by about 50mm, if you do a body swap like I just have you need to swap the whole steering column as the IFS one is shorter
You can buy a 2wd steering shaft and shorten it down to the length required *NOTE* must be shortened properly for on-road certification.
I hate signatures
