hi there new to this site and there seems to be some very nolagable ppl on here so thought i would pick someones brain.
my problum is i bought a manual 2.8 4runner i cant get the 4wd to select u can hear a clicking and the 4wd light comes on and stright away clicks off. it will still select low but omly 2wd cand someone help?????????
mike
surf/4runner 4wd not selecting
Re: surf/4runner 4wd not selecting
1st thing does it have manual hubs.........2nd check the vacuum hose from diff up to alt should be a couple of regs inbetween the lines make sure they are connected thats all i can think of...........good luck
WARNING:
i just had a look and all vacume hoses are conected apart from one ontop of the ac pump vac hose goses in the bottom but unshore if it a cap or pipe off the top. how do i check the solinids and the diafram????
and its auto hubs
and its auto hubs
Hey Mike get rid of it and get a zuk lol.
mazdamike wrote:i just had a look and all vacume hoses are conected apart from one ontop of the ac pump vac hose goses in the bottom but unshore if it a cap or pipe off the top. how do i check the solinids and the diafram????
and its auto hubs
The solenoids should have a resistance of between 37 & 44 Ohms & there are 2 solenoids....no idea how to check diaphram..my ex was always on the pill
lol i might get a zuki too lol bit small to tow the float thow
thanks tallsam i will get out there and check shorty
