are ln60 and ln61 diff holders 100ml wider than ln106s? i want to push my wheels out to fill out my fender flares and getting hold of a ln60 diff holder is cheaper than buying spacers. any info would be appriciated
thanks
How wide do your wheels sit out?
- Driver/Navigator
1998 Toyota Hilux Double Cab Ln106 2.8D 5sp, 33" Kumho Kl71s, Safari Snorkel, 2" body lift and still modifying
Re: How wide do your wheels sit out?
You can get the centres in your rims shifted to give you a bigger offset, I had mine done (centres flipped) and ended up with about 65 or 75mm wider offset on my rims. Cost $30 per rim.
ln61 ifs rear diffs are wider than the solid axle ln60
- hosehustler
Phil_LN106 wrote:are ln60 and ln61 diff holders 100ml wider than ln106s? i want to push my wheels out to fill out my fender flares and getting hold of a ln60 diff holder is cheaper than buying spacers. any info would be appriciated
thanks
LN60 diff housings are identical in width to your LN106, best way to widen your track is to put the REAR axle housng(complete with axles) from a LN61 (2 door IFS surf) it will bolt straight in as spring mounts are in the same place, it's 75mm wider.
You'll then have to widen the front out to match, there is no hilux front axle housing wide enough, best (and certifiable) option is to use IFS front hubs and a spacer/adapter to sort the rotor, these are available from SNR4x4.
Scroll down in my build on the below link for details
viewtopic.php?f=18&t=13066&st=0&sk=t&sd=a&start=30
I hate signatures
