ln130 tailgate issues
after havin a play in the weekend i can not get the tail gate window to open by switch or by key has anyone got any suggestions
- muddyhilux
Re: ln130 tailgate issues
cables run from rear LHS corner,out of floor then up into tailgate,no chance youve damaged wires?
- mike
- Last minute Mike
mine would do the same when it got wet inside. came right after awhile. did you get it wet perhaps. could be an easy fix.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
No easy way apart from removing interior trim and powering up window motor.
Relay most common fault with them.
Make sure window tracks and regulator are well lubed - as lack of lube is what kills relay most of the time (too much load on glass overloads relay).
Checked all the fuses? You never know you might be lucky and just have a blown fuse.
mike wrote:mine would do the same when it got wet inside. came right after awhile. did you get it wet perhaps. could be an easy fix.
we took it for a swimm accross the waimak
mudbugga wrote:No easy way apart from removing interior trim and powering up window motor.
where is the relay for it?????
gimmemud wrote:Checked all the fuses? You never know you might be lucky and just have a blown fuse.
that was the first thing i done
- hosehustler
check this too, they have a circut breaker at the interior fuse board (inside cab by drivers foot), you can poke a small nail or pin in it to push it in to reset, they are sometimes overloaded by holding the up/down switch on too long.
I hate signatures
hosehustler wrote:check this too, they have a circut breaker at the interior fuse board (inside cab by drivers foot), you can poke a small nail or pin in it to push it in to reset, they are sometimes overloaded by holding the up/down switch on too long.
thanks will do that now
http://forums.bauchan.org/portal/downloads.php
Enter in Relay there and one result should come up,
click on download and bingo !
To Boon or not to Boon.
