15x9.5" Proside Laguna Rims
RustySurf
Post by RustySurf »
Have a bit of curbing but nothing too bad, look to be 2 piece.
Universal measurement of dish says it all, are a bit dirty but would polish up choice with some autosol
Wanting $600 will ship them no prob if the buyer pays
RustySurf
Re: 15x9.5" Proside Laguna Rims
Post by RustySurf »
bump
T-Boon
Post by T-Boon »
what offset ?
Guess theyre off a surf ?
To Boon or not to Boon.
RustySurf
Post by RustySurf »
32p Yea were on a surf
corosafari
Post by corosafari »
Are you sure about offset
Looking at cellphone plus clearance dish is about 120mm deep which would be about zero offset on 91/2 rim. Can you confirm measurement from mounting flange to inside of rim, also pcd is 139.7 mm, thanks as interested. Where r u?
RustySurf
Post by RustySurf »
Measured and its 90mm, tyre shop told me they were that offset so took their word for it.
Im located in Te Puke
I reckon they are a hell negative offset
are you able to take a pic of the backside of the cleanest one and as close as possible
there should be stamping etc on there, if its not that readable in the pic you take, then please post up what is written
cheers dude
SKID
corosafari
Cell phone probably a bit longer than mine, was thinking more like a neg offset, more likely 32neg if 32 is number on rim. As a 91/2 " rim with +38 would have about 150mm backspace which would not fit safari, catch on tie rod on inside of rim, just needed to check on that.
Ok thanks for that, will pm.
RustySurf
Post by RustySurf »
Have had a look on the rims and there is no stamping to indicate offset,there are stickers but I cant make anything out on them
RustySurf
Post by RustySurf »
Have done some measurements
Overall width -268mm
Mounting face to inside lip -90mm
268mm/2=134mm centerline of rim
90mm-134mm=-44mm
Makes them a negative 44 offset
RustySurf
Post by RustySurf »
RustySurf
Post by RustySurf »
bump $400
T-Boon
Post by T-Boon »
Would you take $300 and could you drop off to omokaroa for a little extra ? say $50 ? :D
RustySurf
Post by RustySurf »
yep
T-Boon
Post by T-Boon »
cool, lemme know when suits delivery, any time before the weekend after labour weekend, and i`ll chuck some $$ in your account.
