right just exploring options here.
my 3y is sold so realy need to find a motor quick smart.. im considering other things but a 3L is appealing cause they are pretty well respected and can be turboed easily... and its toyota.
Anybody on here replaced a petrol hilux motor with a diesel and can give me some heads up on issues i might face?
Will a 3L bolt up to a G series box with an L series bell housing?
how will i go with engine mounts, will i have to grind and replace the whole mount from the chassis or can i get bolt ons?
im trying to keep this repower as simple as possible
Jared
replacing 3y with a 3L
Re: replacing 3y with a 3L
Most of the drizzles used the w56 box because of the stronger input shaft and the thumping that diesels' give them. Having said that, I think (but am not %100 sure) that the 3l (2.
was only put in front of the R series gearboxes, which are stronger again than the w series. And of course the g series was at the bottom of the heap.
So even if you could mount it up nice and easy to the g, why would you? I you are going to go to this much effort (time and cash) spend a bit more of both and build a decent strength unit.
IMO anyway.
IMO anyway.
pretty sure my old 95 ln106 with the 3l (2.
had a g52 behind it, all factory.
I stand corrected.
Having said that though, if you are building as a 4x4 toy with reasonable sized tyres, why not build it a bit stronger?
sweet that answers that question....
Rok i think the g52 is underated sometimes, yea its not the strongest but Jafas had the g52, gimmemud has a g52 behind a comy v6..
its a start point anyway to get me rollin again..
and if that fails the w series will bolt up the same anyways.
after posting this question I recieved an offer to purchase a damaged yet driveable (just) VR comy with v6 with only 160ks on it for $500
bodys stuffed but everything else is sweet.
Damn ide be able to sell enough parts easy to make back the money... Free motor
problem is if i was to grab it i gota find somewhere to store it till motor comes out
hint hint anyone
yup big ups to the g52! seemed to be fine behind a 350. And it didnt drive it quietly lol
