can someone explain exactly how manual hub setup works with locking the axles to the diff...
just nearing the end of rebuilding my swivel housing on the lux and fitting up the axles/cvs then the sleeve then backing plate noticed the axle isnt locked into the diff..... ie i can rotate diff or and axles dont turn..
is this right? then the axles become locked when i lock the hubs??
Note: ive bolted everything up to the backing plate, rotor and hubs not on yet
just wana be completely sure before i bolt the final bits on
Jared
toyota swivel housing question
Re: toyota swivel housing question
yea i know all that but as far as axles locking to diff???
do the hubs lock the axles to the diff??
im sure its right, piecs a piss to strip it and refit everything just wanting to double check the operation before I re-fit to vehicle
just make sure the cv axle fits into housing properly .it wont go back together if its not right .The cv ball should be just inside the ball. hope this helps .I can see it in my head but hard to put into words
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
Hi Jared,
The FW hubs do not make the axles lock into the diff side gears.
The axles are always fitted into the side gears so there is always drive from the side gear to the CV, the FW hubs engage or disengage between the end ofthe CV and the wheel hub.
If I am correct in thinking that you have got a lockright you may find that the axle will turn without turning the diff or the other axle, this is because when there is no load on the diff the side gear is disengaged from the centre part of the lockright.
Hope that makes sense.
Tim
Tim
no lockrite in the front, just open.
everything up to the backing plate is bolted up, so just the rotor and hubs to go..
and everything has bolted nice and tight and all faces matched up tight, but when turning the diff, the axle/cv doesnt turn..
note that just 1 side is done so far, so do both sides need to be bolted up and weight on the axle????????
Open diff will do that
J_Dub wrote:note that just 1 side is done so far, so do both sides need to be bolted up and weight on the axle????????
If one axle is out of the truck, then turning the diff will just turn the unconnected (No axle in it) spider gear in the diff head, not the axle that's in place.
You need both axle's in the diff to be able to turn the diff input shaft and see hubs turning...
(Can see it in my head, just not write it down that well...)
It's just more fun in a lada !!
roger. so im good to go
cheers fellas
cheers fellas
