kzn130 speedo
mikee
kzn130 speedo
Post by mikee »
Hi does any one know were I can buy in nz a correction unit for my speedo so I can run 35' tyres,thanks.
UBZ
Re: kzn130 speedo
Post by UBZ »
change your diff ratios to correct the difference in tyre size
ie if stock ratio on 31's is 4.1
then 4.3 will work with 33's
and 4.5 with 35's
speedo should be close to correct depending on actual tyre size
wjw
Re: kzn130 speedo
Post by wjw »
Where are you based?
These guys do it in Christchurch, $250 for the last one I got done.
http://www.eparrott.co.nz/
I have a an adapter to go from 31's to 35's from my KZJ78 Prado, sits between the speedo cable and gearbox. It might fit. What model gearbox do you have?
Who knew Prados could fly?
axel
Re: kzn130 speedo
Post by axel »
Hey wjw do you still have the speedo adaptor mentioned? I also have a kzj78 also running 35's? Cheers
SamLogan
Re: kzn130 speedo
Post by SamLogan »
jaycar makes a do it yourself kit so you solder it together. It then means you don't need to ever worry about it again as you have 100% adjustment either way. it sells for about $68 i believe. Its called speedo adjustment kit mkII i believe
Sam
mikee
Re: kzn130 speedo
Post by mikee »
Got one of those sent it back only got sledge hammer,grinder and welding skills to delicate for me. :twisted: :twisted:
