Hilux gearbox / trans questions
Petemcc
Post by Petemcc »
Hi guys,
My ln106 lux has a box out of a surf in it with push button 4wd. I'm not sure exactly which one it is and won't be able to check for a couple of weeks but the guy it got it off said it was out of a v6 and he fitted it as it had stronger internals than the standard box which had lost a gear.
My problem is that this box seems to be shorter than the original as he has a spacer on the rear drive shaft. I would like to swap it back to get rid of the spacer and would rather the standard transfer over the push button.
Which bit of the box I have is shorter? Could I just swap the transfers or should I swap the whole lot.
Are the bell housings the same?
If anyone can give a bit of a run down on what the different boxes are and their interchangeability that would be great.
Pete
hosehustler
Re: Hilux gearbox / trans questions
Post by hosehustler »
LN106 original box is a G52, and transfer box is the std manual type with the transfer stick remotely mounted on the gearbox.
It's a real common setup, as for the bellhousing there's many that will bolt on to the G52 box....what engine is it on :?:
I hate signatures
meatc
Post by meatc »
I looked into this a while back as there are a few slightly different ratios. From what I remember
early ones : top shifter (in top of transfer) are the same as the manual shift forward shift (shift lever just forward of transfer)
Vacum shift (push button) are chain drive transfer rather than gear, housing is different and wont bolt to older box,
Then there is a later one that is different again and shares auto trans oil or some thing.
But basically I dont think you can swap the earlier manual shift transfer. :(
rangimotors
Post by rangimotors »
if the only problem is the spacer is it easier to just get a new drive shaft made up or sleave and extend yours and have it balanced?
Petemcc
Post by Petemcc »
Cheers guys,
motor was a 3l and now has a 5l.
I would rather have the standard transfer than the push button type to get rid of the electrics. The last owner wired it up to a button on the dash rather than the standard button on the leaver and it is just all a bit of a hash. Standard drive shaft and no spacer would be a preference.
Pretty sure my box is an R series box but will have to check next time I'm in town.
so looks like I'm looking for a G52 with an L series bell housing assuming that the current L series to presumably R series box won't fit to the G52.
Are all boxes from L series engines with manual shift G52s?
hosehustler
R series won't fit, the G or a W will, best std option is to find a L series bell (diesel), anything will do, and a box, you can use a W series box (1986-1988 diesel 2 door surfs) as they have the trans shifter straight out of the t-case...nice G-box but some massaging to your trans tunnel Req.
if you need any more info in Chch PM me
I hate signatures
Petemcc
Post by Petemcc »
Cheers Tim that should be enough to go off for now.
I suppose another option to get rid of the spacer could be to put up with the transfer I have an see if a 130 surf drive shaft would fit? Might have to do some measuring
Petemcc
Post by Petemcc »
Can you tell from this pic if this a G52? Says it's out of a ln61
hosehustler
W series and he's correct on model, to use that box you will need a bellhousing (he may have one, as that box would have been behind a 2LT)
the G52 with it's transfercase, and the w56 with it's transfercase, these 2 combinations are the same overall length, a L series bell will bolt to either.
you will have to chop around the floor a little if you use a w series as said, the trans case stick comes out of the top of T-case.
I hate signatures
Petemcc
Post by Petemcc »
I am back looking at this now but because I purchased duals off Tim!
A guy stripping a heap of hiluxs on trademe said that the w, g and r series boxes have different sized input shafts (must mean diameter for the g and w if they are the same length) is this true?
Will I be able to use my current clutch plate when I swap to a w or g series box? (currently have a 5L motor with and R series box.)
Pete
Crash bandicoot
Post by Crash bandicoot »
differing input shafts isnt a huge issue, just different clutch plate and spigot bearing in the flywheel, i had a drive shaft spacer made up by taylor engineering in wanganui, cost me all of 30 bucks and a box of beer. much easier then changing transfer and gearboxes around
ToyRover
Post by ToyRover »
i would keep the box you have now the r series out of the 90 plus surfs with push botton 4wd is so much stronger the g and w arnt that good r series is cheaper to replace and easy to find
