Hey guys,
Just wondering if anyone has put a 1hdt into a KZj78, just thinking what id do if my 1kz let go....
the older round head light 70 series came out with a non turbo 1HD didnt they? So are the factory kzj78 mounts going to match uip with the 1hdt?
1hdt into kzj78
Re: 1hdt into kzj78
its a pretty long motor to try and squeeze into a 4 cly engine bay, V8s are pretty tight and there shorter than a 6 cly engine but anythings possible
Re: 1hdt into kzj78
But didnet the same truck come out with a 6 cylender anyway?
http://www.trademe.co.nz/motors/used-ca ... 826361.htm
Same as this.
Same as this.
Re: 1hdt into kzj78
From the firewall forward they are completely differant in length.
Re: 1hdt into kzj78
yeah but that ones not a prado mate its a leaf sprung cruiser with the longer engine bay
Re: 1hdt into kzj78
Prados have a shorter chassis, the body is similar. do a search on here for 1kzte, remove egr, bigger exhaust, manual pump if you want more power, 1kz is a great motor . biggest issue really is the heads but these are not to bad to replace costwise.
Anything modified costs $$$ 1uzfe just squeezes in looking at least 10g for a drive in drive out conversion.
Re: 1hdt into kzj78
If you've got heaps of time ,a good read, this basicly what you would need to do.
http://forum.ih8mud.com/70-series-tech/ ... build.html
- mudlva
Re: 1hdt into kzj78
Lawrence wrote:Hey guys,
thought of the 13/14 bt motor shit load more torque and if it pushes the LC's around it'll move a prado
Re: 1hdt into kzj78
Stick with the 1kz
