rear 80 series springs wanted
sg8380
Post by sg8380 »
hey im after some rear 80 series landcruiser springs to put in a ln130 surf
Thanks, Sam
1989 Surf ln130 2lt
31 maxxis buckshots
2 inch suspension lift
Smurf
Re: rear 80 series springs wanted
Post by Smurf »
How are you going to level out the front once you have lifted the rear 4 or more inches?
rowdyrunner
Newbie
Newbie
Post by rowdyrunner »
Gidday i can get you a pair of them cheap if you like. PM me
Big
Post by Big »
got some.. pm me if needed..
sg8380
Post by sg8380 »
hey ill just wind the torsion bars up in the front, my mate has just done it to his and it looks good
1989 Surf ln130 2lt
31 maxxis buckshots
evolution02
Post by evolution02 »
Smurf wrote:How are you going to level out the front once you have lifted the rear 4 or more inches?
Smurf says this as you can only get about 2 inches out of the torsion bars. If you wind them to far you will be against the bump stops and have no travel left
sg8380
Post by sg8380 »
whats the other option i have to raise it?
1989 Surf ln130 2lt
31 maxxis buckshots
jonossiksilvia
Post by jonossiksilvia »
sas but not a cheap option
sg8380
Post by sg8380 »
Just wondering what an sas is? Haha
1989 Surf ln130 2lt
31 maxxis buckshots
keithal
Post by keithal »
sas is a solid axle swap
there have been a few done recently on here
have a look in Tomsoffroad thread and you will see jammysammy's surf with a prado front axle
sg8380
Post by sg8380 »
What would the cheapest and easiest option be to raise it
1989 Surf ln130 2lt
31 maxxis buckshots
keithal
Post by keithal »
50mm spring lift/shocks in the rear and wind the torsions to suit
sg8380
Post by sg8380 »
Do front springs off a 80 series land cruiser fit in and give it a 50 mm lift from standard height?
1989 Surf ln130 2lt
31 maxxis buckshots
Smurf
Post by Smurf »
80 series fronts are a different diameter coil and don't fit. Will also lift higher than the 80 series rear.
sg8380
Post by sg8380 »
Ok thanks for that ill just stick to the 50mm lift springs then
1989 Surf ln130 2lt
31 maxxis buckshots
