where to buy alloy fiarlead with offet holes to fit arb bar
need one like tiger11 on trade me use to sell with the holes off set down so i can use bolts that hold winch in to hold it any help would be good
Re: where to buy alloy fiarlead with offet holes to fit arb
Like this one?
Try Tigerz 11. Brett good to deal with.
http://www.tigerz11.co.nz/Winch_Accessories.php
http://www.4wdbits.co.nz/ProductsList.a ... egoryID=23
3 Sizes, unsure which one you might need?
Bit Pricier than the Tigerz ones though, maybe drop them a line and see if they can budge?
To Boon or not to Boon.
They look off-set
I have used one of those though, in an off-set application. You just need a few special tools, e.g, Drills to suit a large tap (10-13mm)(3/8-1/2) and a counter bore cutter to make a couple of holes in the back to accommodate the winch lower mount bolts.
The lower holes are the centre of the bored out voids.
They look off-set
try your local ARB shop?
I had the same issue on my old truck. My uncle "borrowed" a bit of 15mm alloy plate from the paper mill where he works and chucked my drawing into the CNC cutter..only issue was, he figured I had measured wrong on the drawing and he moved the holes back to the center
lol
sibainmud wrote:^^^^^^
They look off-set![]()
has the rope ever rubed on the lip where the rollers bolted on to
Nah not really. I was going to cut it off and weld a smaller bit of material to it as a strong back.....but.......I'm going to have to retire that bar soon as it suffered some serious warpage last weekend and is almost past saving.
