Cruiser diff heads
Cruiser diff heads
Quick question about Cruiser LSD. I'm looking at putting in a LSD in the front
Sadam said that they may not be that good to swap
Whats the general consensus?
Benjamin Franklin
Benjamin Franklin
Bubba wrote:Knew you would be the man, Sounds all good to me, problem being a rear locka costs to many $$$ at the moment, in time it will come
best 600 you will ever spend on it tho dude
i run the locker in the rear and a nice tight lsd up front. Seems to work sweet, although you do get a little bit of a twitch in the steering if the lsd does "slip" But nothing scary and you soon get used to how it handles. Its only an issue in 4WD. As Wop said it is good insurance for CVs
Long term i will fit a locker in the front
but not before i've bought longfields
i know this is toyota forum BUT, i had a lsd fitted in the front my safari out of the rear lsd terrano,and it goes really good well chuffed with it i know its a poor mans locker but spent too much on the old girl this year for a locker, have driven other 4x4's with a diff locks up the front they are better,i have a tight rear lsd and it goes in same places where other trucks are diff locked front and rear
vince..........
vince..........
While on the topic can I thread jack?
Thanks.
My truck had a LSD in the rear, its since been fitted with a locker. Will the rear LSD fit in the front? Some one mentioned that the front an rear diffs may be different? The LSD is still with the guy I bought the truck off as he forgot to get it to me but if I can fit it I'm gonna chase it up?
Thanks.
the lsd will fit as long as you have a standard cruiser front diff. approx 1990 on they changed the front diff to the small up pinion ,ie 80 series front which is hilux size so if you have one of these your lsd out of the back wont fit
Re: Cruiser diff heads
Well, its been a while in the making but it's in now. I have yet to drive in anger but on the road it's no different and the brakes have stopped pulling to one side (bonus!)
Benjamin Franklin
Benjamin Franklin
