new motor time
new motor time
my hilux 2 l is poked so need new engine. thought of building my engine but would rather build or swap in a good 3l or 5l if possible .What have you got . Cheers Ray
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
Re: new motor time
http://www.trademe.co.nz/motors/car-par ... 299936.htm
can't be anything major to sort the idle out??
Re: new motor time
saw that seems too cheap .Would be ideal though
Re: new motor time
that engine doesn't look right.
its silver top not black which typically indicates the early engine but its got 2lte turbo gear fitted which normally doesn't fit the early ones.
someones welded in a pipe where the butterfly system normally is.
Re: new motor time
It's been a while since I worked on one but isn't that a 2LT motor, looks like it to me, but then I am getting
OLD .
FITZY.
OLD .
FITZY.
Re: new motor time
tweake wrote:that engine doesn't look right.
My 2L-TE has the same silver top. It has had a 3L head fitted so I am guessing this motor for sale is a turboed 3L or at least a 3L head on a 2L-T block?
Re: new motor time
I ended up getting that 3l turbo off trade me for 800 .Will see if good buy or not .will my glow plug system be the same from 2l to 3l.Cheers For help
Re: new motor time
Good score. Did you suss what was wrong with it? It almost sounds like the timing belt is a tooth or two out?
Re: new motor time
fingers crossed its simple fix.will sus it when it gets here.i have a good pump man thats a bonus
Re: new motor time
of the top of my head if you use 3l glows in it then it will work fine with the old 2l glow system in the hilux. hilux will be a timer setup. the 2lt had a dual stage superglow system and i think it used 9v glows instead of the 12v glows hilux uses.
Re: new motor time
will a 2 inch exhaust be big enough for this engine
Re: new motor time
simple answer.......no.
big bore only if its 2.8 and highly recommended for the 2.4 as well.
having said that it won't die if your drive quietly but keep running full noise and the extra backpressure wil cause high egts and eventually kill the engine.
Re: new motor time
just what the wife wants to hear .more money on the bloody ute .
anyone got one laying around
