new motor time
rayndeb
new motor time
Post by rayndeb »
my hilux 2 l is poked so need new engine. thought of building my engine but would rather build or swap in a good 3l or 5l if possible .What have you got . Cheers Ray
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
Smurf
Re: new motor time
Post by Smurf »
http://www.trademe.co.nz/motors/car-par ... 299936.htm
can't be anything major to sort the idle out??
rayndeb
Re: new motor time
Post by rayndeb »
saw that seems too cheap .Would be ideal though
tweake
Re: new motor time
Post by tweake »
that engine doesn't look right.
its silver top not black which typically indicates the early engine but its got 2lte turbo gear fitted which normally doesn't fit the early ones.
someones welded in a pipe where the butterfly system normally is.
SMOKEY
Re: new motor time
Post by SMOKEY »
It's been a while since I worked on one but isn't that a 2LT motor, looks like it to me, but then I am getting
OLD .
FITZY.
Smurf
Re: new motor time
Post by Smurf »
tweake wrote:that engine doesn't look right.
My 2L-TE has the same silver top. It has had a 3L head fitted so I am guessing this motor for sale is a turboed 3L or at least a 3L head on a 2L-T block?
rayndeb
Re: new motor time
Post by rayndeb »
I ended up getting that 3l turbo off trade me for 800 .Will see if good buy or not .will my glow plug system be the same from 2l to 3l.Cheers For help
Smurf
Re: new motor time
Post by Smurf »
Good score. Did you suss what was wrong with it? It almost sounds like the timing belt is a tooth or two out?
rayndeb
Re: new motor time
Post by rayndeb »
fingers crossed its simple fix.will sus it when it gets here.i have a good pump man thats a bonus
tweake
Re: new motor time
Post by tweake »
of the top of my head if you use 3l glows in it then it will work fine with the old 2l glow system in the hilux. hilux will be a timer setup. the 2lt had a dual stage superglow system and i think it used 9v glows instead of the 12v glows hilux uses.
rayndeb
Re: new motor time
Post by rayndeb »
will a 2 inch exhaust be big enough for this engine
tweake
Re: new motor time
Post by tweake »
simple answer.......no.
big bore only if its 2.8 and highly recommended for the 2.4 as well.
having said that it won't die if your drive quietly but keep running full noise and the extra backpressure wil cause high egts and eventually kill the engine.
rayndeb
Re: new motor time
Post by rayndeb »
just what the wife wants to hear .more money on the bloody ute . :lol:
anyone got one laying around
